Saltar al contenido principal
Kodak EasyShare Z1015 IS SD Memory Card Replacement
Qué necesitas
  1. Kodak EasyShare Z1015 IS SD Memory Card Replacement, SD Memory Card: paso 1, imagen 1 de 2 Kodak EasyShare Z1015 IS SD Memory Card Replacement, SD Memory Card: paso 1, imagen 2 de 2
    • In order to remove the SD memory card, you will first need to open up the cover. To open the cover, slide the latch holding the cover in place to the left.
    • Remove your hand from the latch and the cover should pop open. The SD memory card is located near the top above the battery. As shown in the final picture of this step.
  2. Kodak EasyShare Z1015 IS SD Memory Card Replacement: paso 2, imagen 1 de 2 Kodak EasyShare Z1015 IS SD Memory Card Replacement: paso 2, imagen 2 de 2
    • After locating the SD card, gently push down on the card and release. This will cause the SD card to pop out of its position in the camera as shown in the second picture of this step.
  3. Kodak EasyShare Z1015 IS SD Memory Card Replacement: paso 3, imagen 1 de 2 Kodak EasyShare Z1015 IS SD Memory Card Replacement: paso 3, imagen 2 de 2
    • After removing the SD card from its locked position, gently pull the SD card out from the container to successfully remove it from the camera.
Conclusión
Una persona más ha completado esta guía.
katie newman
Miembro Desde 10/28/10
30 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-16, Maness Fall 2010 Miembro de Cal Poly, Team 5-16, Maness Fall 2010
CPSU-MANESS-F10S5G16
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 2,744
