Saltar al contenido principal
Kodak EasyShare V570 Jammed Shutter Button Fix
Qué necesitas
  1. Kodak EasyShare V570 Jammed Shutter Button Fix, Kodak EasyShare V570 Jammed Shutter Button Fix: paso 1, imagen 1 de 3 Kodak EasyShare V570 Jammed Shutter Button Fix, Kodak EasyShare V570 Jammed Shutter Button Fix: paso 1, imagen 2 de 3 Kodak EasyShare V570 Jammed Shutter Button Fix, Kodak EasyShare V570 Jammed Shutter Button Fix: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Make sure that the tools are acquired, The 70% Isopropyl Alcohol and Q-tips are needed, but if the tweezers are not available that is okay. Fingernails or a credit card are just fine. Anything that can move the button without damaging it works.
  2. Kodak EasyShare V570 Jammed Shutter Button Fix: paso 2, imagen 1 de 3 Kodak EasyShare V570 Jammed Shutter Button Fix: paso 2, imagen 2 de 3 Kodak EasyShare V570 Jammed Shutter Button Fix: paso 2, imagen 3 de 3
    • Pour a little bit of the alcohol into the cap
    • Take the Q-tip and sink the cotton end into the cap
    • Move the Q-tip onto the Shutter Button and move it around in circular motions
    • While the alcohol is still wet use the choice of tool and try to wiggle the button back and forth
    • After the button is wiggled a couple of times, try and see if the button is able to be pushed down.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 61
