Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This camera has easy access to the battery. The place in which you would find the battery also houses the memory card. Don't be alarmed, because there is a diagram on the inside that just incase you didn't know which went into which slot it can show you.
Herramientas
No se especificaron herramientas.
Partes
  1. Flip the camera upside down so the battery compartment is towards you. Follow the arrows with your thumb to slide open the hatch to expose the battery and memory card.
    • Flip the camera upside down so the battery compartment is towards you. Follow the arrows with your thumb to slide open the hatch to expose the battery and memory card.
  2. This is what it should look like once it is opened. Here you can take the old battery out or take the memory card out as well.
    • This is what it should look like once it is opened. Here you can take the old battery out or take the memory card out as well.
  3. SALTEA LA ACTUALIZACIÓN
    Ahorra reparando con un kit todo en uno.
    Compra Kits de Reparación
  4. The diagram shows the (-) side should be on your right, while the (+) side should be on your left. Insert the new battery and memory card here.
    • The diagram shows the (-) side should be on your right, while the (+) side should be on your left. Insert the new battery and memory card here.
  5. Close up the hatch and you're back to taking beautiful pictures!
    • Close up the hatch and you're back to taking beautiful pictures!
Conclusión
Close it back up and you're ready to go!
Una persona más ha completado esta guía.
Elizabeth
Miembro Desde 28/01/15
279 Reputación
2 Guías creadas
Equipo
Penn State, Team 1-2, Kaschak Winter 2015 Miembro de Penn State, Team 1-2, Kaschak Winter 2015
PSU-KASCHAK-W15S1G2
1 Miembro
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 28
Todo El Tiempo: 961
