Saltar al contenido principal
Kodak EasyShare M381 Screen Replacement
Qué necesitas
  1. Kodak EasyShare M381 Screen Replacement, Battery: paso 1, imagen 1 de 2 Kodak EasyShare M381 Screen Replacement, Battery: paso 1, imagen 2 de 2
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Screen Replacement: paso 2, imagen 1 de 1
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Screen Replacement, Back Panel Frame: paso 3, imagen 1 de 3 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: paso 3, imagen 2 de 3 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: paso 3, imagen 3 de 3
    • Obtain screwdriver, and remove the 3.85 mm frame screws as highlighted.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  4. Kodak EasyShare M381 Screen Replacement: paso 4, imagen 1 de 2 Kodak EasyShare M381 Screen Replacement: paso 4, imagen 2 de 2
    • After screws are removed, using both hands, carefully pull the frame apart from the camera as indicated.
  5. Kodak EasyShare M381 Screen Replacement, Screen: paso 5, imagen 1 de 1
    • Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
  6. Kodak EasyShare M381 Screen Replacement: paso 6, imagen 1 de 1
    • Remove dial button located on top of camera, by gently pulling up.
  7. Kodak EasyShare M381 Screen Replacement: paso 7, imagen 1 de 2 Kodak EasyShare M381 Screen Replacement: paso 7, imagen 2 de 2
    • Starting at one side, carefully work the chrome frame off of the camera itself.
    • Be careful not to disturb the shutter or flash buttons on top of the camera.
  8. Kodak EasyShare M381 Screen Replacement: paso 8, imagen 1 de 1
    • On the right side of the camera, locate and remove the two 3.25 mm screws as highlighted.
  9. Kodak EasyShare M381 Screen Replacement: paso 9, imagen 1 de 3 Kodak EasyShare M381 Screen Replacement: paso 9, imagen 2 de 3 Kodak EasyShare M381 Screen Replacement: paso 9, imagen 3 de 3
    • Carefully lift the motherboard panel up, pulling towards the left. Make sure you do not rip the blue ribbon.
    • Using a plastic opening tool, gently lift up on the ribbon fastener until it is in an upright position.
    • Slide panel away from camera.
  10. Kodak EasyShare M381 Screen Replacement: paso 10, imagen 1 de 2 Kodak EasyShare M381 Screen Replacement: paso 10, imagen 2 de 2
    • Using a plastic opening tool, gently lift ribbon clamp as indicated to remove the screen ribbon from the motherboard.
    • Screen should now be detached. Gently lift it away from the base of the camera.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 342
