Introducción
Technology in the lens can often become dysfunctional. This guide will show you how to remove it, so you can clean or replace it. Lens Part Number: k9711061632 2ba
Qué necesitas
First, press in and slide forward the battery latch as indicated by the arrow.
Obtain screwdriver, and remove the 3.85 mm frame screws as highlighted.
Locate and remove the four 3.25 mm screws securing the back panel to the frame of the camera using the Phillips #00 screwdriver.
Lift up and remove panel, detaching it from the camera frame.
Casi Terminas!
Conclusión
