Introducción
The battery latch can often crack, making the battery connection very weak. This guide will outline how to remove and replace it.
Qué necesitas
First, press in and slide forward the battery latch as indicated by the arrow.
Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
Locate and remove selector dial on the top of the camera.
This should free the chrome mid-frame that encompasses the camera. Carefully lift and remove it as well.
