Saltar al contenido principal
Kodak EasyShare M2008 Lens Replacement
Qué necesitas
  1. Kodak EasyShare M2008 Lens Replacement, Battery: paso 1, imagen 1 de 2 Kodak EasyShare M2008 Lens Replacement, Battery: paso 1, imagen 2 de 2
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Kodak EasyShare M2008 Lens Replacement: paso 2, imagen 1 de 2 Kodak EasyShare M2008 Lens Replacement: paso 2, imagen 2 de 2
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Kodak EasyShare M2008 Lens Replacement, Device Casing: paso 3, imagen 1 de 3 Kodak EasyShare M2008 Lens Replacement, Device Casing: paso 3, imagen 2 de 3 Kodak EasyShare M2008 Lens Replacement, Device Casing: paso 3, imagen 3 de 3
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Kodak EasyShare M2008 Lens Replacement: paso 4, imagen 1 de 3 Kodak EasyShare M2008 Lens Replacement: paso 4, imagen 2 de 3 Kodak EasyShare M2008 Lens Replacement: paso 4, imagen 3 de 3
    • Gently lift off front and back casing.
  5. Kodak EasyShare M2008 Lens Replacement: paso 5, imagen 1 de 3 Kodak EasyShare M2008 Lens Replacement: paso 5, imagen 2 de 3 Kodak EasyShare M2008 Lens Replacement: paso 5, imagen 3 de 3
    • Remove screws along side.
    • Gently peel off side casing.
  6. Kodak EasyShare M2008 Lens Replacement, Lens: paso 6, imagen 1 de 3 Kodak EasyShare M2008 Lens Replacement, Lens: paso 6, imagen 2 de 3 Kodak EasyShare M2008 Lens Replacement, Lens: paso 6, imagen 3 de 3
    • Remove screws from front silver panel.
  7. Kodak EasyShare M2008 Lens Replacement: paso 7, imagen 1 de 3 Kodak EasyShare M2008 Lens Replacement: paso 7, imagen 2 de 3 Kodak EasyShare M2008 Lens Replacement: paso 7, imagen 3 de 3
    • Lift up ribbon cable fastener with blue plastic opening tool.
    • Gently pull out lens.
  8. Kodak EasyShare M2008 Lens Replacement: paso 8, imagen 1 de 1
    • To place new lens, peel off silver tape before inserting ribbon cable into proper slot.
Conclusión
Una persona más ha completado esta guía.
Brian
Miembro Desde 03/13/14
252 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 12
Todo El Tiempo: 282
