Saltar al contenido principal
Kodak EasyShare M2008 LCD Screen Replacement
Qué necesitas
  1. Kodak EasyShare M2008 LCD Screen Replacement, Battery: paso 1, imagen 1 de 2 Kodak EasyShare M2008 LCD Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Kodak EasyShare M2008 LCD Screen Replacement: paso 2, imagen 1 de 2 Kodak EasyShare M2008 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Kodak EasyShare M2008 LCD Screen Replacement, Device Casing: paso 3, imagen 1 de 3 Kodak EasyShare M2008 LCD Screen Replacement, Device Casing: paso 3, imagen 2 de 3 Kodak EasyShare M2008 LCD Screen Replacement, Device Casing: paso 3, imagen 3 de 3
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Kodak EasyShare M2008 LCD Screen Replacement: paso 4, imagen 1 de 3 Kodak EasyShare M2008 LCD Screen Replacement: paso 4, imagen 2 de 3 Kodak EasyShare M2008 LCD Screen Replacement: paso 4, imagen 3 de 3
    • Gently lift off front and back casing.
  5. Kodak EasyShare M2008 LCD Screen Replacement: paso 5, imagen 1 de 3 Kodak EasyShare M2008 LCD Screen Replacement: paso 5, imagen 2 de 3 Kodak EasyShare M2008 LCD Screen Replacement: paso 5, imagen 3 de 3
    • Remove screws along side.
    • Gently peel off side casing.
  6. Kodak EasyShare M2008 LCD Screen Replacement, LCD Screen: paso 6, imagen 1 de 2 Kodak EasyShare M2008 LCD Screen Replacement, LCD Screen: paso 6, imagen 2 de 2
    • Gently lift up the LCD screen after removing back casing.
    • Find the point where the orange ribbon cable attaches to mother board.
  7. Kodak EasyShare M2008 LCD Screen Replacement: paso 7, imagen 1 de 2 Kodak EasyShare M2008 LCD Screen Replacement: paso 7, imagen 2 de 2
    • Use plastic opening tool to gently lift up on the ribbon cable fastener.
    • Note: It does not take much pressure to release fastener.
  8. Kodak EasyShare M2008 LCD Screen Replacement: paso 8, imagen 1 de 1
    • Lift LCD Screen off of device.
Conclusión
Una persona más ha completado esta guía.
Brian
Miembro Desde 03/13/14
252 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 219
