Saltar al contenido principal
Kodak EasyShare M2008 Battery Door Replacement
Qué necesitas
  1. Kodak EasyShare M2008 Battery Door Replacement, Battery: paso 1, imagen 1 de 2 Kodak EasyShare M2008 Battery Door Replacement, Battery: paso 1, imagen 2 de 2
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Kodak EasyShare M2008 Battery Door Replacement: paso 2, imagen 1 de 2 Kodak EasyShare M2008 Battery Door Replacement: paso 2, imagen 2 de 2
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Kodak EasyShare M2008 Battery Door Replacement, Device Casing: paso 3, imagen 1 de 3 Kodak EasyShare M2008 Battery Door Replacement, Device Casing: paso 3, imagen 2 de 3 Kodak EasyShare M2008 Battery Door Replacement, Device Casing: paso 3, imagen 3 de 3
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Kodak EasyShare M2008 Battery Door Replacement: paso 4, imagen 1 de 3 Kodak EasyShare M2008 Battery Door Replacement: paso 4, imagen 2 de 3 Kodak EasyShare M2008 Battery Door Replacement: paso 4, imagen 3 de 3
    • Gently lift off front and back casing.
  5. Kodak EasyShare M2008 Battery Door Replacement: paso 5, imagen 1 de 3 Kodak EasyShare M2008 Battery Door Replacement: paso 5, imagen 2 de 3 Kodak EasyShare M2008 Battery Door Replacement: paso 5, imagen 3 de 3
    • Remove screws along side.
    • Gently peel off side casing.
  6. Kodak EasyShare M2008 Battery Door Replacement, Battery Door: paso 6, imagen 1 de 3 Kodak EasyShare M2008 Battery Door Replacement, Battery Door: paso 6, imagen 2 de 3 Kodak EasyShare M2008 Battery Door Replacement, Battery Door: paso 6, imagen 3 de 3
    • Open the battery door and identify the retaining pin.
    • Push retaining pin out with small tweezers.
  7. Kodak EasyShare M2008 Battery Door Replacement: paso 7, imagen 1 de 3 Kodak EasyShare M2008 Battery Door Replacement: paso 7, imagen 2 de 3 Kodak EasyShare M2008 Battery Door Replacement: paso 7, imagen 3 de 3
    • Once pin is out halfway, close door to ensure no loose parts get lost.
    • Continue to pull out the remaining length of the pin.
  8. Kodak EasyShare M2008 Battery Door Replacement: paso 8, imagen 1 de 2 Kodak EasyShare M2008 Battery Door Replacement: paso 8, imagen 2 de 2
    • Gently lift off door cover.
Conclusión
Kyanna
Miembro Desde 03/13/14
313 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 6
Todo El Tiempo: 162
