Saltar al contenido principal
Kodak EasyShare LS743 Microphone Replacement
Qué necesitas
  1. Kodak EasyShare LS743 Microphone Replacement, Battery: paso 1, imagen 1 de 1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Microphone Replacement: paso 2, imagen 1 de 1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: paso 3, imagen 1 de 3 Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: paso 3, imagen 2 de 3 Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: paso 3, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Microphone Replacement: paso 4, imagen 1 de 3 Kodak EasyShare LS743 Microphone Replacement: paso 4, imagen 2 de 3 Kodak EasyShare LS743 Microphone Replacement: paso 4, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Microphone Replacement: paso 5, imagen 1 de 2 Kodak EasyShare LS743 Microphone Replacement: paso 5, imagen 2 de 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Microphone Replacement, Top and menu buttons: paso 6, imagen 1 de 2 Kodak EasyShare LS743 Microphone Replacement, Top and menu buttons: paso 6, imagen 2 de 2
    • Remove the top panel screw (1x 4.37mm).
  7. Kodak EasyShare LS743 Microphone Replacement: paso 7, imagen 1 de 2 Kodak EasyShare LS743 Microphone Replacement: paso 7, imagen 2 de 2
    • Remove the top panel.
  8. Kodak EasyShare LS743 Microphone Replacement: paso 8, imagen 1 de 2 Kodak EasyShare LS743 Microphone Replacement: paso 8, imagen 2 de 2
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
  9. Kodak EasyShare LS743 Microphone Replacement: paso 9, imagen 1 de 3 Kodak EasyShare LS743 Microphone Replacement: paso 9, imagen 2 de 3 Kodak EasyShare LS743 Microphone Replacement: paso 9, imagen 3 de 3
    • Separate the inner casing from the tripod mount.
  10. Kodak EasyShare LS743 Microphone Replacement: paso 10, imagen 1 de 3 Kodak EasyShare LS743 Microphone Replacement: paso 10, imagen 2 de 3 Kodak EasyShare LS743 Microphone Replacement: paso 10, imagen 3 de 3
    • Gently pull the orange tab out of the circuit board.
  11. Kodak EasyShare LS743 Microphone Replacement: paso 11, imagen 1 de 2 Kodak EasyShare LS743 Microphone Replacement: paso 11, imagen 2 de 2
    • Carefully separate and flip over the LCD panel to expose the central circuit board.
  12. Kodak EasyShare LS743 Microphone Replacement: paso 12, imagen 1 de 1
    • Remove the (1x 3.33mm) screw from the menu button panel .
  13. Kodak EasyShare LS743 Microphone Replacement: paso 13, imagen 1 de 2 Kodak EasyShare LS743 Microphone Replacement: paso 13, imagen 2 de 2
    • Pull the second orange tab from the circuit board and remove the buttons.
  14. Kodak EasyShare LS743 Microphone Replacement, Removing LCD: paso 14, imagen 1 de 3 Kodak EasyShare LS743 Microphone Replacement, Removing LCD: paso 14, imagen 2 de 3 Kodak EasyShare LS743 Microphone Replacement, Removing LCD: paso 14, imagen 3 de 3
    • Flip up the LCD screen to reveal the two orange ribbon cables.
    • Disconnect the two ribbons cables from their sockets on the motherboard.
  15. Kodak EasyShare LS743 Microphone Replacement, Microphone: paso 15, imagen 1 de 1
    • Locate the microphone on top of the camera.
  16. Kodak EasyShare LS743 Microphone Replacement: paso 16, imagen 1 de 1
    • With an opening tool, pry the microphone away from the camera carefully.
  17. Kodak EasyShare LS743 Microphone Replacement: paso 17, imagen 1 de 1
    • Release the microphone from its pin and desolder.
Conclusión
Una persona más ha completado esta guía.
Odessa
Miembro Desde 06/24/10
55 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-8, Johann Summer 2010 Miembro de Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 2,017
