Saltar al contenido principal
Kodak EasyShare LS743 Camera Case Disassembly
Qué necesitas
  1. Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: paso 1, imagen 1 de 3 Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: paso 1, imagen 2 de 3 Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: paso 1, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  2. Kodak EasyShare LS743 Camera Case Disassembly: paso 2, imagen 1 de 3 Kodak EasyShare LS743 Camera Case Disassembly: paso 2, imagen 2 de 3 Kodak EasyShare LS743 Camera Case Disassembly: paso 2, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  3. Kodak EasyShare LS743 Camera Case Disassembly: paso 3, imagen 1 de 2 Kodak EasyShare LS743 Camera Case Disassembly: paso 3, imagen 2 de 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
Conclusión
Una persona más ha completado esta guía.
Michael
Miembro Desde 06/24/10
63 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-8, Johann Summer 2010 Miembro de Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 2,038
