Introducción
Use this guide to disassemble a Kodak EasyShare CD82, in order to remove and replace the LCD display screen.
  1. Remove the batteries and the memory card from the device. Remove the 2 screws located at the bottom of the device. Remove the 2 screws located at the bottom of the device.
    • Remove the batteries and the memory card from the device.
    • Remove the 2 screws located at the bottom of the device.
  2. Remove the 2 screws on the side, to the left of the camera lens. Remove the 2 screws on the side, to the right of the camera lens. Pry the casing from the device starting at the battery compartment and following the seem around the camera.
    • Remove the 2 screws on the side, to the left of the camera lens.
    • Remove the 2 screws on the side, to the right of the camera lens.
    • Pry the casing from the device starting at the battery compartment and following the seem around the camera.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  4. Remove the front panel from the device first, then remove the back panel. Do not remove the LCD screen from the device once it becomes visible. Do not remove the LCD screen from the device once it becomes visible.
    • Remove the front panel from the device first, then remove the back panel.
    • Do not remove the LCD screen from the device once it becomes visible.
  5. Flip the LCD screen away from the top of the device to reveal the ribbon cable. This is water damage the has afflicted the camera. Remove the 3 screws from the LCD screen holder.
    • Flip the LCD screen away from the top of the device to reveal the ribbon cable.
      • This is water damage the has afflicted the camera.
    • Remove the 3 screws from the LCD screen holder.
    • Pry the screen holder from the circuit board connector.
  6. Disconnect the logic board from the right side of the frame. Remove the small ribbon cable that is connecting the button panel to the logic board, using a small pair of tweezers or hemostat.
    • Disconnect the logic board from the right side of the frame.
      • Remove the small ribbon cable that is connecting the button panel to the logic board, using a small pair of tweezers or hemostat.
      • Remove the screw on the top right side of the device.
  7. Open the connector and move the black clip into the upward position, freeing the cable. Remove the LCD screen and the holder. While the camera is disassembled, use isopropyl alcohol to remove rust and clean the device.
    • Open the connector and move the black clip into the upward position, freeing the cable. Remove the LCD screen and the holder.
      • While the camera is disassembled, use isopropyl alcohol to remove rust and clean the device.
    • Follow these steps in reverse order to reassemble. The device should be fully functional upon completion.
Conclusión
Una persona más ha completado esta guía.
oldturkey03
Miembro Desde 29/09/10
560,007 Reputación
101 Guías creadas
Equipo
OTS Miembro de OTS
Business
1 Miembro
123 Guías creadas
Is there any repair for Kodak CD80 easy share camera…..as my camera is not working
Januchowdary - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,129
