Saltar al contenido principal
Kodak EasyShare C913 LCD Screen Replacement
Qué necesitas
  1. Kodak EasyShare C913 LCD Screen Replacement, Batteries: paso 1, imagen 1 de 3 Kodak EasyShare C913 LCD Screen Replacement, Batteries: paso 1, imagen 2 de 3 Kodak EasyShare C913 LCD Screen Replacement, Batteries: paso 1, imagen 3 de 3
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 LCD Screen Replacement, Back Case: paso 2, imagen 1 de 3 Kodak EasyShare C913 LCD Screen Replacement, Back Case: paso 2, imagen 2 de 3 Kodak EasyShare C913 LCD Screen Replacement, Back Case: paso 2, imagen 3 de 3
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 on the left
    • 2 on the right
    • 3 on the bottom
  3. Kodak EasyShare C913 LCD Screen Replacement: paso 3, imagen 1 de 3 Kodak EasyShare C913 LCD Screen Replacement: paso 3, imagen 2 de 3 Kodak EasyShare C913 LCD Screen Replacement: paso 3, imagen 3 de 3
    • Firmly grasp the back of the camera and pull the away the casing.
  4. Kodak EasyShare C913 LCD Screen Replacement, Front Case: paso 4, imagen 1 de 3 Kodak EasyShare C913 LCD Screen Replacement, Front Case: paso 4, imagen 2 de 3 Kodak EasyShare C913 LCD Screen Replacement, Front Case: paso 4, imagen 3 de 3
    • Keep the battery door open
    • Firmly grasp the front casing and pull away from the camera.
  5. Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: paso 5, imagen 1 de 3 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: paso 5, imagen 2 de 3 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: paso 5, imagen 3 de 3
    • Locate the 2 solder joints on both sides of the LCD casing.
    • De-solder the joints.
  6. Kodak EasyShare C913 LCD Screen Replacement: paso 6, imagen 1 de 3 Kodak EasyShare C913 LCD Screen Replacement: paso 6, imagen 2 de 3 Kodak EasyShare C913 LCD Screen Replacement: paso 6, imagen 3 de 3
    • Gently grasp the lower right side of LCD screen.
    • Lift the screen out of its casing.
    • Remove 3mm screw from LCD casing using #00 screwdriver.
  7. Kodak EasyShare C913 LCD Screen Replacement: paso 7, imagen 1 de 3 Kodak EasyShare C913 LCD Screen Replacement: paso 7, imagen 2 de 3 Kodak EasyShare C913 LCD Screen Replacement: paso 7, imagen 3 de 3
    • Gently grab the sides of the LCD casing and remove it from the camera
  8. Kodak EasyShare C913 LCD Screen Replacement: paso 8, imagen 1 de 2 Kodak EasyShare C913 LCD Screen Replacement: paso 8, imagen 2 de 2
    • Lift the black tab with your finger
    • Gently remove ribbon from underneath black tab.
Conclusión
Una persona más ha completado esta guía.
Alan Galarza
Miembro Desde 10/03/10
72 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-51, Amido Fall 2010 Miembro de Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 4,240
