Introducción
Use this guide to remove the capacitor.
Herramientas
Partes
No se requieren partes.
Position the camera with the bottom facing up.
With your finger, slide the battery cover in the direction of open arrow.
The battery cover will spring open, so be careful to lift it up gently.
Use a Phillips #00 screwdriver to remove the seven 4.5mm screws.
There are 2 on the left
There are 2 on the right
There are 3 on the bottom
With battery door open, grasp the front case and remove it from the camera.
Orient the camera with the lens facing you.
Use a Phillips #00 screwdriver to remove the one 2.2mm screw on the plastic bridge.
Lift the plastic bridge off and place it to the side.
