Saltar al contenido principal
Kodak EasyShare C713 Lens Replacement
Qué necesitas
  1. Kodak EasyShare C713 Lens Replacement, Batteries: paso 1, imagen 1 de 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Lens Replacement: paso 2, imagen 1 de 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Lens Replacement, Outer Case: paso 3, imagen 1 de 3 Kodak EasyShare C713 Lens Replacement, Outer Case: paso 3, imagen 2 de 3 Kodak EasyShare C713 Lens Replacement, Outer Case: paso 3, imagen 3 de 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Lens Replacement: paso 4, imagen 1 de 3 Kodak EasyShare C713 Lens Replacement: paso 4, imagen 2 de 3 Kodak EasyShare C713 Lens Replacement: paso 4, imagen 3 de 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Lens Replacement, LCD: paso 5, imagen 1 de 1
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
  6. Kodak EasyShare C713 Lens Replacement: paso 6, imagen 1 de 1
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Kodak EasyShare C713 Lens Replacement: paso 7, imagen 1 de 2 Kodak EasyShare C713 Lens Replacement: paso 7, imagen 2 de 2
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. Kodak EasyShare C713 Lens Replacement: paso 8, imagen 1 de 1
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Kodak EasyShare C713 Lens Replacement: paso 9, imagen 1 de 1
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
  10. Kodak EasyShare C713 Lens Replacement: paso 10, imagen 1 de 1
    • Remove the LCD ribbon cable from inside the black tab.
  11. Kodak EasyShare C713 Lens Replacement, Lens: paso 11, imagen 1 de 1
    • Using a fingertip, flip the black tab near the top of the camera.
    • Remove the ribbon connector from inside the black tab.
  12. Kodak EasyShare C713 Lens Replacement: paso 12, imagen 1 de 1
    • Remove the remaining eight 4.1mm screws on the back with the Phillips #00 screwdriver.
  13. Kodak EasyShare C713 Lens Replacement: paso 13, imagen 1 de 1
    • Desolder the upper points.
    • There is a series of solder points in a rectangular area in the upper middle of the camera.
    • There is a large solder point in the upper right.
  14. Kodak EasyShare C713 Lens Replacement: paso 14, imagen 1 de 1
    • Turn the camera over.
    • Remove the silver 2.2mm battery cap screw.
  15. Kodak EasyShare C713 Lens Replacement: paso 15, imagen 1 de 2 Kodak EasyShare C713 Lens Replacement: paso 15, imagen 2 de 2
    • Pry the capacitor out of its holder on the bottom of the camera with your fingers.
  16. Kodak EasyShare C713 Lens Replacement: paso 16, imagen 1 de 3 Kodak EasyShare C713 Lens Replacement: paso 16, imagen 2 de 3 Kodak EasyShare C713 Lens Replacement: paso 16, imagen 3 de 3
    • Remove the lens assembly with your fingers.
    • You may need to wiggle it back and forth until it comes loose.
    • Do not touch the marked areas. This will cause the camera to take blurry pictures.
Conclusión
Una persona más ha completado esta guía.
Taggart Ashby
Miembro Desde 04/15/10
354 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 26-19, Regan Spring 2010 Miembro de Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Miembros
14 Guías creadas
Un comentario
why didn't you mention to discharge the capacitor, its stored charge is pretty high & dangerous
richard - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 36
Todo El Tiempo: 7,026
