Introducción
Removing and replacing the lens.
Herramientas
Partes
No se requieren partes.
Use your finger tip to slide battery cover door away from the center of the camera.
The battery door should spring open.
If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Remove 7 screws from the outer case with a Phillips #00.
All screws are 4.45mm.
There are 2 screws on the port side.
There are 2 screws on starboard side.
There are 3 screws on the bottom.
Put your thumb in the upper right corner of the LCD Screen.
Pull the LCD screen out of it's outer case with your thumb.
Using a fingertip, flip the black tab near the top of the camera.
Remove the ribbon connector from inside the black tab.
Una persona más ha completado esta guía.
