Saltar al contenido principal
Kodak EasyShare C713 Capacitor Replacement
Qué necesitas
  1. Kodak EasyShare C713 Capacitor Replacement, Batteries: paso 1, imagen 1 de 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Capacitor Replacement: paso 2, imagen 1 de 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Capacitor Replacement, Outer Case: paso 3, imagen 1 de 3 Kodak EasyShare C713 Capacitor Replacement, Outer Case: paso 3, imagen 2 de 3 Kodak EasyShare C713 Capacitor Replacement, Outer Case: paso 3, imagen 3 de 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Capacitor Replacement: paso 4, imagen 1 de 3 Kodak EasyShare C713 Capacitor Replacement: paso 4, imagen 2 de 3 Kodak EasyShare C713 Capacitor Replacement: paso 4, imagen 3 de 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Capacitor Replacement, Capacitor: paso 5, imagen 1 de 2 Kodak EasyShare C713 Capacitor Replacement, Capacitor: paso 5, imagen 2 de 2
    • To avoid an electric shock, do not to touch capacitor.
    • The capacitor is located underneath the lens.
    • It is held in place by 4 plastic snaps; it can be easily removed by pulling outward with your fingers.
  6. Kodak EasyShare C713 Capacitor Replacement: paso 6, imagen 1 de 1
    • Desolder points connecting capacitor to circuit board.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 26-19, Regan Spring 2010 Miembro de Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 4,217
