Saltar al contenido principal
Kodak EasyShare C713 Buttons Replacement
Qué necesitas
  1. Kodak EasyShare C713 Buttons Replacement, Batteries: paso 1, imagen 1 de 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Buttons Replacement: paso 2, imagen 1 de 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Buttons Replacement, Outer Case: paso 3, imagen 1 de 3 Kodak EasyShare C713 Buttons Replacement, Outer Case: paso 3, imagen 2 de 3 Kodak EasyShare C713 Buttons Replacement, Outer Case: paso 3, imagen 3 de 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Buttons Replacement: paso 4, imagen 1 de 3 Kodak EasyShare C713 Buttons Replacement: paso 4, imagen 2 de 3 Kodak EasyShare C713 Buttons Replacement: paso 4, imagen 3 de 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Buttons Replacement, Buttons: paso 5, imagen 1 de 1
    • Remove the necessary broken buttons.
    • They come out easily so just use your fingers.
Conclusión
Una persona más ha completado esta guía.
Taggart Ashby
Miembro Desde 04/15/10
354 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 26-19, Regan Spring 2010 Miembro de Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 2,940
