Saltar al contenido principal
Kodak EasyShare C713 Battery Door Replacement
Qué necesitas
  1. Kodak EasyShare C713 Battery Door Replacement, Batteries: paso 1, imagen 1 de 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Battery Door Replacement: paso 2, imagen 1 de 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Battery Door Replacement, Outer Case: paso 3, imagen 1 de 3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: paso 3, imagen 2 de 3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: paso 3, imagen 3 de 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Battery Door Replacement: paso 4, imagen 1 de 3 Kodak EasyShare C713 Battery Door Replacement: paso 4, imagen 2 de 3 Kodak EasyShare C713 Battery Door Replacement: paso 4, imagen 3 de 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Battery Door Replacement, Battery Door: paso 5, imagen 1 de 2 Kodak EasyShare C713 Battery Door Replacement, Battery Door: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Make sure the battery door is open.
    • Using a pair of tweezers, remove the metal rod at the junction of the battery door and the inner camera case.
    • This rod serves as the hinge for the door.
    • Make sure not to lose the battery door spring which may fall when the rod is removed.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 26-19, Regan Spring 2010 Miembro de Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Miembros
14 Guías creadas
Un comentario
Where do I buy a new battery door. Cheers, Peter
Peter - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 30
Todo El Tiempo: 5,241
