Saltar al contenido principal
Kodak EasyShare C195 Batteries Replacement
Qué necesitas
  1. Kodak EasyShare C195 Batteries Replacement, Batteries: paso 1, imagen 1 de 3 Kodak EasyShare C195 Batteries Replacement, Batteries: paso 1, imagen 2 de 3 Kodak EasyShare C195 Batteries Replacement, Batteries: paso 1, imagen 3 de 3
    • First, open the cover to the batteries. This is located on the bottom left of the camera.
    • Push the door down and to the left to open. This opens into the batteries and the memory card.
  2. Kodak EasyShare C195 Batteries Replacement: paso 2, imagen 1 de 3 Kodak EasyShare C195 Batteries Replacement: paso 2, imagen 2 de 3 Kodak EasyShare C195 Batteries Replacement: paso 2, imagen 3 de 3
    • To insert the batteries, place them in the slots provided.
    • Make sure the positive and negative signs match with the positive and negative sides of the batteries.
  3. Kodak EasyShare C195 Batteries Replacement: paso 3, imagen 1 de 3 Kodak EasyShare C195 Batteries Replacement: paso 3, imagen 2 de 3 Kodak EasyShare C195 Batteries Replacement: paso 3, imagen 3 de 3
    • When finished, you should have one battery positive side up and the other one negative side up.
Conclusión
To close the door, push the door down and slide to the right
Alyssa
Miembro Desde 04/12/12
81 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-22, Amido Spring 2012 Miembro de Cal Poly, Team 6-22, Amido Spring 2012
CPSU-AMIDO-S12S6G22
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 64
Todo El Tiempo: 3,099
