Qué necesitas
Use a TX10 screwdriver
Remove the housing screws on the rear of the device.
6 long screws
3 short screws
Place the device with the white lid facing up.
Start to carefully lift the lid at the front of the suction nozzle. Slowly work your way up to the stem.
Now you can lift the flap of the vacuum cleaner bag. This was only held by the white lid.
Disconnect the power supply connector by pressing the unlocking lever.
Unplug the motherboard connector.
Put the cable aside
Unlock and loosen the rotary switch plug.
Disconnect the white air hose from the intake manifold.
Release 2 plastic clips
Remove the wiring harness with the plastic holder.
Follow the steps in reverse order to reassemble your device.
Un agradecimiento especial a estos traductores:
100%
¡ oldturkey03 nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
