Saltar al contenido principal
Partes
No se especificaron partes.
  1. Pull on the corner to remove the cover. Pull on the corner to remove the cover.
    • Pull on the corner to remove the cover.
  2. Remove the six screws.
    • Remove the six screws.
    • Remove the back of the device.
  3. Kits de reparación de iPhone X
    ¿Garantía vencida? No te preocupes, tenemos la solución.
    Comprar Ahora
    Comprar Ahora
  4. Remove the four screws from the mother board.
    • Remove the four screws from the mother board.
    • Remove the screen connector and the battery connector.
    • Remove the micro SD card.
    • Remove the motherboard from the chassis.
  5. Remove the four screws from the screen frame. Remove the screen
    • Remove the four screws from the screen frame.
    • Remove the screen
  6. And we finally finished.
    • And we finally finished.
Linea de Meta
Una persona más ha completado esta guía.
Gabriel Bédard
Miembro Desde 07/06/18
131 Reputación
1 Guía escrita
Just a quick note, I noticed that the SD card in the teardown is a 4gb one. The Kobo Mini has only 2gb of storage. There's just under 2gb of unpartitioned space. You can use a partition manager to extend out the last partition to fill the card, and get close to 4gb of space.
There's a guide over on Mobile Read: https://www.mobileread.com/forums/showth...
Stephanie Raccoon - Contestar
Yes I think
Gabriel Bédard -
Thanks for the teardown! See https://www.mobileread.com/forums/showth... and https://wiki.mobileread.com/wiki/Kobo_Mi... for more disassembly advice and information about the components used.
I would be concerned about the reliability of the 4GB micro SD cards when extended to use the full unpartitioned space. While I could imagine a situation where 4GB cards were used due to unavailability of 2GB cards, there doesn’t seem to be a good reason to only format them to 2GB unless they were only guaranteed to reliably hold 2GB of data. In other words, I wonder if they were originally 4GB cards that failed some QA test and were only rated for use as 2GB capacity cards.
David Boddie - Contestar
How do you remove the battery connector? Simply pull? Remove the black little things on the sides in some way?
jasonhayden - Contestar
Yes you just need to pull it from the motherboard
Gabriel Bédard -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 35
Todo El Tiempo: 825
