Saltar al contenido principal
Kobo Arc K107 USB Replacement
Qué necesitas
  1. Kobo Arc K107 USB Replacement, Battery: paso 1, imagen 1 de 1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 USB Replacement: paso 2, imagen 1 de 1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 USB Replacement: paso 3, imagen 1 de 1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 USB Replacement: paso 4, imagen 1 de 1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Kobo Arc K107 USB Replacement, USB: paso 5, imagen 1 de 1
    • Remove the motherboard from the outer case.
  6. Kobo Arc K107 USB Replacement: paso 6, imagen 1 de 1
    • Detach the USB cable from the motherboard.
    • Remove the USB port from the tablet.
Conclusión
Ray Starpoli
Miembro Desde 10/28/21
169 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 Miembro de UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 282
