Saltar al contenido principal
KitchenAid Professional 600 Worm Gear Replacement
Qué necesitas
  1. KitchenAid Professional 600 Worm Gear Replacement, Top Cover: paso 1, imagen 1 de 1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Worm Gear Replacement: paso 2, imagen 1 de 1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Worm Gear Replacement: paso 3, imagen 1 de 1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Worm Gear Replacement, Gear Housing Cover: paso 4, imagen 1 de 1
    • Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
    • Only one of the screws is seen in the picture. The other three are also located around the black housing cover.
  5. KitchenAid Professional 600 Worm Gear Replacement: paso 5, imagen 1 de 1
    • Take off the black housing cover.
  6. KitchenAid Professional 600 Worm Gear Replacement, Worm Gear: paso 6, imagen 1 de 1
    • Remove the Worm Gear.
    • The Worm Gear is the part that is lying horizontal.
    • Remember to apply food safe grease onto your new replacement part before assembling the device back together.
Conclusión
9 personas más completaron esta guía.
Luke
Miembro Desde 04/11/16
1,353 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 25-4, Maness Spring 2016 Miembro de Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
4 Miembros
18 Guías creadas
Un comentario
No tiene ningún tornillo a los lado eso es mentira
Guillermo Perez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 54
Ultimos 30 días: 206
Todo El Tiempo: 18,928
