Introducción
As an expensive mixer that is built to last, some key components do go bad from time to time. Overall, your investment, with a few fixes along the way, will nearly last a lifetime. This guide will demystify your repair to your KitchenAid Pro stand mixer.
Qué necesitas
Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
Remove the silver band.
Locate the selector switch.
Remove the two Phillips #2 screws holding the selector switch in place.
4 personas más completaron esta guía.
7 comentarios
The instructions are to unplug the cords from the motor but the removed selector switch pictured shows the cords were removed from the selector switch. Is there a way to remove the cords from the selector switch without breaking them? donmilo@yahoo.com
The replacement part looks like a major part in the mixer and probably costs a bundle like most replacement parts… sometimes deems the replacement “not worthy” to repair!
It’s like a car that cost $25K but, all its parts if you buy them separately, it will cost you $150K !!!
The speed selector MSRP is $89.99 and can be found on places like eBay for $35-60. For only needing some simple tools and a little time, this fix saves you from the cost of buying a new one. These are designed to be repaired/refurbished.
The advice about kitchenaid600 switch was good. The form to get me able to say thanks was not.
