Saltar al contenido principal
KitchenAid Professional 600 Power Cord Replacement
Qué necesitas
  1. KitchenAid Professional 600 Power Cord Replacement, Top Cover: paso 1, imagen 1 de 1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Power Cord Replacement: paso 2, imagen 1 de 1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Power Cord Replacement: paso 3, imagen 1 de 1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Power Cord Replacement, Speed Selector: paso 4, imagen 1 de 1
    • Locate the selector switch.
    • Remove the two Phillips #2 screws holding the selector switch in place.
  5. KitchenAid Professional 600 Power Cord Replacement: paso 5, imagen 1 de 3 KitchenAid Professional 600 Power Cord Replacement: paso 5, imagen 2 de 3 KitchenAid Professional 600 Power Cord Replacement: paso 5, imagen 3 de 3
    • Unplug the cords attached the drive motor to the switch.
    • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
  6. KitchenAid Professional 600 Power Cord Replacement: paso 6, imagen 1 de 1
    • Pull out the Selector Switch.
  7. KitchenAid Professional 600 Power Cord Replacement, Drive Motor: paso 7, imagen 1 de 1
    • Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
    • The picture only shows one of the screws. The other screw is located on the exact opposite side of the motor.
  8. KitchenAid Professional 600 Power Cord Replacement: paso 8, imagen 1 de 1
    • Pull upward to remove the motor.
  9. KitchenAid Professional 600 Power Cord Replacement, Power Cord: paso 9, imagen 1 de 1
    • Remove the Phillips #2 screw attaching the green grounding wire to the frame of the mixer.
  10. KitchenAid Professional 600 Power Cord Replacement: paso 10, imagen 1 de 1
    • Remove the three Phillips #2 screws that connect the top portion of the mixer to the "neck" of the mixer.
  11. KitchenAid Professional 600 Power Cord Replacement: paso 11, imagen 1 de 1
    • Remove the top portion of the mixer from the "neck" of the mixer.
    • This will make removing the power cord much easier.
  12. KitchenAid Professional 600 Power Cord Replacement: paso 12, imagen 1 de 1
    • You can now remove the power cord from the mixer.
Conclusión
Una persona más ha completado esta guía.
Luke
Miembro Desde 04/11/16
1,380 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 25-4, Maness Spring 2016 Miembro de Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
4 Miembros
18 Guías creadas
2 comentarios
So helpful thank you. I've got my mixer cord changer and the mixer is working now. Unfortunately there's always only one speed, high. Any suggestions?
Britter C - Contestar
Any idea where I can buy the power cord itself?
Jaeger Amzallag - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 54
Todo El Tiempo: 5,780
