Qué necesitas
Extrae el tornillo que sujeta la banda plateada con un destornillador Phillips nº 2.
Retira la banda plateada.
Retira los 4 tornillos Phillips nº 2 que conectan la tapa negra de la carcasa al dispositivo.
Para desmontar el engranaje cónico, retira el anillo elástico que rodea la base del engranaje con unos alicates para anillos elásticos.
Para volver a montar el dispositivo, sigue estas instrucciones en orden inverso.
10 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Carlos López (España - Spain) nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
14 comentarios
I was thinking , - my god what a excelent tec. contribution material before watched your naked hands whit a lot of greasy spots
I’m from Ensenada Baja California “mother land of the internatiomal score baja off-road races“ and here we have a Doctor Simi drugstore’s where you can buy a pair of natural latex gloves whit or whitout powder s - m - l for less than one u.s. dollar. I buy gloves in monday’s because i pay 10 mexican pesos for it. “The little details son los que la cagan “
Need to know if after removing this bevel gear, does that allow the gear below it to be removed also? Because this is the one I need to replace.
Thanks
Once the Bevel Gear is removed you will see a pin that can be pushed out with a punch or small screw driver. That allows to you to remove the Worm Follower Gear. Keep you hand under the machine as the whole shaft can slide down. It’s pretty straight forward.
I removed the snap ring but my bevel gear is locked and I cannot remove it. I suspect the pin located below it is broken. Any suggestion? What can I do to replace both bevel and worm gears?
