Saltar al contenido principal
KitchenAid KSM150PSER Speed Control Plate Replacement
Qué necesitas
  1. KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: paso 1, imagen 1 de 2 KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: paso 1, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
  2. KitchenAid KSM150PSER Speed Control Plate Replacement: paso 2, imagen 1 de 3 KitchenAid KSM150PSER Speed Control Plate Replacement: paso 2, imagen 2 de 3 KitchenAid KSM150PSER Speed Control Plate Replacement: paso 2, imagen 3 de 3
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
  3. KitchenAid KSM150PSER Speed Control Plate Replacement: paso 3, imagen 1 de 3 KitchenAid KSM150PSER Speed Control Plate Replacement: paso 3, imagen 2 de 3 KitchenAid KSM150PSER Speed Control Plate Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using a Phillips #2 screwdriver, remove the 12mm screw by holding the grounding wire in place and rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the speed control plate.
  4. KitchenAid KSM150PSER Speed Control Plate Replacement: paso 4, imagen 1 de 2 KitchenAid KSM150PSER Speed Control Plate Replacement: paso 4, imagen 2 de 2
    • Remove the seal from the back of the mixer. Then unhook the spring from the bottom of the speed control plate by using tweezers and pulling it back and out of the plate.
    • Take a rag or towel and hook the spring on the towel so that the hook doesn’t spring back inside the mixer.
  5. KitchenAid KSM150PSER Speed Control Plate Replacement: paso 5, imagen 1 de 2 KitchenAid KSM150PSER Speed Control Plate Replacement: paso 5, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the two adjustment screws by rotating them counterclockwise.
    • Before beginning to remove the screws, use a ruler and measure how far the screws are in. These screws determine the speed of the mixer, and not screwing them back in to the same position will change the speed of the mixer.
  6. KitchenAid KSM150PSER Speed Control Plate Replacement: paso 6, imagen 1 de 1
    • The control plate can now be removed by pulling back on the plate.
Conclusión
8 personas más completaron esta guía.
Richa Gadgil
Miembro Desde 01/24/18
313 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S2-G5, Livingston Winter 2018 Miembro de Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Miembros
10 Guías creadas
Un comentario
Thanks for this, but a quick question, when the mixer is switched off, the metal bar on the back of the speed plate at the bottom, is that supposed to rest on the two prongs that stick out towards the bottom of the inside of the mixer? Thanks.
Mark R (dflipb) - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 36
Ultimos 30 días: 177
Todo El Tiempo: 19,106
