Saltar al contenido principal
KitchenAid KSM150PSER Power Cord Replacement
Qué necesitas
  1. KitchenAid KSM150PSER Power Cord Replacement, Power Cord: paso 1, imagen 1 de 2 KitchenAid KSM150PSER Power Cord Replacement, Power Cord: paso 1, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
  2. KitchenAid KSM150PSER Power Cord Replacement: paso 2, imagen 1 de 2 KitchenAid KSM150PSER Power Cord Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
  3. KitchenAid KSM150PSER Power Cord Replacement: paso 3, imagen 1 de 2 KitchenAid KSM150PSER Power Cord Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using a Phillips #2 screwdriver, remove the 12mm screw holding the grounding wire in place by rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the white and black wires.
  4. KitchenAid KSM150PSER Power Cord Replacement: paso 4, imagen 1 de 2 KitchenAid KSM150PSER Power Cord Replacement: paso 4, imagen 2 de 2
    • Using a screwdriver, pull the cord string relief out of the mixer by putting it behind the cord and pulling away from the mixer until it is free.
    • Remove the cord from the mixer body.
Conclusión
Max Prohorov
Miembro Desde 01/24/18
109 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S2-G5, Livingston Winter 2018 Miembro de Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 46
Todo El Tiempo: 4,116
