Saltar al contenido principal
KitchenAid KSM150PSER Circuit Board Replacement
Qué necesitas
  1. KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: paso 1, imagen 1 de 2 KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: paso 1, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling it back and up.
    • Ensure that the mixer is disconnected from any electrical source prior to removing the back cover.
  2. KitchenAid KSM150PSER Circuit Board Replacement: paso 2, imagen 1 de 2 KitchenAid KSM150PSER Circuit Board Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the 9.5mm screw above the circuit board by rotating it counterclockwise.
    • If you can't see the screw, try pulling the seal down past the wires to make the screw more accessible.
  3. KitchenAid KSM150PSER Circuit Board Replacement: paso 3, imagen 1 de 2 KitchenAid KSM150PSER Circuit Board Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using pliers or tweezers, remove the connectors of the four wires attached to the circuit board.
  4. KitchenAid KSM150PSER Circuit Board Replacement: paso 4, imagen 1 de 1
    • Grab the wires and tilt the edge of the board up to lift the circuit board up and out.
Conclusión
4 personas más completaron esta guía.
Luke Leonard
Miembro Desde 01/24/18
562 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S2-G5, Livingston Winter 2018 Miembro de Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 47
Todo El Tiempo: 5,359
