Saltar al contenido principal
KitchenAid KSM150PSER Carbon Brushes Replacement
Qué necesitas
  1. KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: paso 1, imagen 1 de 2 KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: paso 1, imagen 2 de 2
    • Using a flat head screwdriver, unscrew the brush cap on each side of the mixer by turning them counter clockwise.
    • Remove brush cap by pulling it toward you.
    • The brushes are held in by springs and will fly out if removed too fast.
  2. KitchenAid KSM150PSER Carbon Brushes Replacement: paso 2, imagen 1 de 1
    • Remove brush by pulling it toward you.
    • One corner of the brush is flattened. You can check which way the brush is oriented by shining a flashlight inside the hole.
Conclusión
6 personas más completaron esta guía.
Hayley Young
Miembro Desde 12/03/16
211 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S2-G5, Livingston Winter 2018 Miembro de Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Miembros
10 Guías creadas
Un comentario
I’ve been procrastinating on trying to fix my KA mixer on my own…today I did it. The directions were pretty clear and the only thing wrong was that when I had previously cleaned my mixer, I put the carbon brushes in the wrong way. Once I shined a flashlight into the hole I could see where the notched corner went.
Amber Reimer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 41
Ultimos 30 días: 205
Todo El Tiempo: 14,629
