Saltar al contenido principal
KitchenAid KSB5CR Power Cable Replacement
Qué necesitas
  1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: paso 1, imagen 1 de 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: paso 1, imagen 2 de 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: paso 1, imagen 3 de 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 2: paso 2, imagen 1 de 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Power Cable Replacement, Freeing the Power Cable: paso 3, imagen 1 de 1
    • Lift up on the power cable to pop it out of its holder.
  4. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: paso 4, imagen 1 de 2 KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: paso 4, imagen 2 de 2
    • Be gentle with the knife or you will break the circuit board.
    • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
    • Repeat this process with the black copper wire.
  5. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: paso 5, imagen 1 de 2 KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: paso 5, imagen 2 de 2
    • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
Conclusión
Cameron Geehr
Miembro Desde 09/28/14
745 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 12-5, Forte Fall 2014 Miembro de Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 678
