Saltar al contenido principal
KitchenAid KSB5CR Motor Replacement
Qué necesitas
  1. KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: paso 1, imagen 1 de 3 KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: paso 1, imagen 2 de 3 KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: paso 1, imagen 3 de 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 2: paso 2, imagen 1 de 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: paso 3, imagen 1 de 3 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: paso 3, imagen 2 de 3 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: paso 3, imagen 3 de 3
    • Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
    • Remove the ribbon cable from the chassis by lifting it up.
  4. KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: paso 4, imagen 1 de 3 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: paso 4, imagen 2 de 3 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: paso 4, imagen 3 de 3
    • Unhook the white wire that is looped around the peg by pulling it out of the clip.
    • Repeat this process with the red wire on the other side of the chassis.
    • Remove the end cap using the 8" needle nose pliers.
    • Pull up the fan chassis.
  5. KitchenAid KSB5CR Motor Replacement, Removing the Fan: paso 5, imagen 1 de 1
    • Remove the fan by lifting it upwards.
    • This step is difficult and requires force. Use of both hands is recommended.
  6. KitchenAid KSB5CR Motor Replacement, Removing the Metal Cap: paso 6, imagen 1 de 1
    • Use the needle nose pliers to turn the coupling clockwise to loosen it.
  7. KitchenAid KSB5CR Motor Replacement, Removing the Screws: paso 7, imagen 1 de 1
    • Rotate the blender 90 degrees clockwise.
    • Remove the two #8 Phillips 12 mm screws using the Phillips #2 screwdriver.
  8. KitchenAid KSB5CR Motor Replacement, Detatching the Wire: paso 8, imagen 1 de 1
    • Slide the knife in the metal loop holding the insulation before the white copper wire, and wiggle the knife back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
  9. KitchenAid KSB5CR Motor Replacement, Removing the Motor: paso 9, imagen 1 de 1
    • Lift the motor up out of the chassis.
Conclusión
Una persona más ha completado esta guía.
Cameron Geehr
Miembro Desde 09/28/14
745 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 12-5, Forte Fall 2014 Miembro de Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 30
Todo El Tiempo: 4,082
