Saltar al contenido principal
KitchenAid KSB5CR Fan Replacement
Qué necesitas
  1. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: paso 1, imagen 1 de 3 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: paso 1, imagen 2 de 3 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: paso 1, imagen 3 de 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 2: paso 2, imagen 1 de 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: paso 3, imagen 1 de 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: paso 3, imagen 2 de 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: paso 3, imagen 3 de 3
    • Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
    • Remove the ribbon cable from the chassis by lifting it up.
  4. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: paso 4, imagen 1 de 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: paso 4, imagen 2 de 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: paso 4, imagen 3 de 3
    • Unhook the white wire that is looped around the peg by pulling it out of the clip.
    • Repeat this process with the red wire on the other side of the chassis.
    • Remove the end cap using the 8" needle nose pliers.
    • Pull up the fan chassis.
  5. KitchenAid KSB5CR Fan Replacement, Removing the Fan: paso 5, imagen 1 de 1
    • Remove the fan by lifting it upwards.
    • This step is difficult and requires force. Use of both hands is recommended.
Conclusión
Una persona más ha completado esta guía.
Cameron Geehr
Miembro Desde 09/28/14
745 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 12-5, Forte Fall 2014 Miembro de Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Miembros
6 Guías creadas
3 comentarios
Hi,
Do you know if it is possible to convert Kitchenaid Artisan stand mixer to 240v, has anyone looked inside or know if i should change something.
Ancient warrior - Contestar
Does raplacing the fan mean that the fan itself (when broken) can be ordered? So just the white plastic round part. If so, could someone please give me a reference number? Would be highly appreciated.
Hugo, the Netherlands.
Hugo - Contestar
my blender turn on all the numbers light at the same time and is not working at all. do you know what the problem could be?
patricia - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 2,215
