Saltar al contenido principal
KitchenAid KSB5CR Back Panel Removal
Qué necesitas
  1. KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 1: paso 1, imagen 1 de 3 KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 1: paso 1, imagen 2 de 3 KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 1: paso 1, imagen 3 de 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 2: paso 2, imagen 1 de 1
    • Lift the back panel up, sliding it along the power cord.
Conclusión
Cameron Geehr
Miembro Desde 09/28/14
745 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 12-5, Forte Fall 2014 Miembro de Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 617
