Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Is your power cord frayed or damaged? Follow this guide to replace it.
  1. Insert the back of a plastic opening tool into one of the beater holes Apply force to pull the circular plastic part off.
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. Use a plastic opening tool to remove the speed knob. Pop up the panel with a plastic opening tool. Use a plastic opening tool to pry the white plastic switch assembly out.
    • Use a plastic opening tool to remove the speed knob.
    • Pop up the panel with a plastic opening tool.
    • Use a plastic opening tool to pry the white plastic switch assembly out.
  3. Use a Phillips 2 screwdriver to remove the two 20.0mm screws that hold the bottom plastic piece. Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
    • Use a Phillips 2 screwdriver to remove the two 20.0mm screws that hold the bottom plastic piece.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
    • Remove the bottom plastic piece using a plastic opening tool.
  4. Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place. Use your hands to remove the motor assembly and circuit board. Use your hands to remove the motor assembly and circuit board.
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly and circuit board.
  5. Firmly grip the circuit board, and using pliers, remove the black and white power cord connectors from the circuit board. Some force may be required. Be careful not to cut yourself on any electrical components. Some force may be required. Be careful not to cut yourself on any electrical components.
    • Firmly grip the circuit board, and using pliers, remove the black and white power cord connectors from the circuit board.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
  6. Using a plastic opening tool, remove the white plastic clip on the inside of the bottom plastic piece. Once it's loose, remove it with your fingers. Pull the power cord through the hole.
    • Using a plastic opening tool, remove the white plastic clip on the inside of the bottom plastic piece.
    • Once it's loose, remove it with your fingers.
    • Pull the power cord through the hole.
Conclusión
Brad Daniels
Miembro Desde 10/02/16
549 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 2-3, Sullivan Spring 2016 Miembro de USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 38
Todo El Tiempo: 2,325
