Saltar al contenido principal
KitchenAid KHM512ER Motor Replacement
Qué necesitas
  1. KitchenAid KHM512ER Motor Replacement, Motor: paso 1, imagen 1 de 2 KitchenAid KHM512ER Motor Replacement, Motor: paso 1, imagen 2 de 2
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Motor Replacement: paso 2, imagen 1 de 2 KitchenAid KHM512ER Motor Replacement: paso 2, imagen 2 de 2
    • Use a Phillips 2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
  3. KitchenAid KHM512ER Motor Replacement: paso 3, imagen 1 de 2 KitchenAid KHM512ER Motor Replacement: paso 3, imagen 2 de 2
    • Using a Phillips 2 screwdriver, remove the three 20mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly and circuit board.
  4. KitchenAid KHM512ER Motor Replacement: paso 4, imagen 1 de 3 KitchenAid KHM512ER Motor Replacement: paso 4, imagen 2 de 3 KitchenAid KHM512ER Motor Replacement: paso 4, imagen 3 de 3
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
Conclusión
2 personas más completaron esta guía.
[deleted]
Miembro Desde 02/10/16
134 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 4,595
