Saltar al contenido principal
KitchenAid Classic Mixer K45SSWH Gasket Replacement
Qué necesitas
  1. KitchenAid Classic Mixer K45SSWH Gasket Replacement, Motor Housing Cover: paso 1, imagen 1 de 2 KitchenAid Classic Mixer K45SSWH Gasket Replacement, Motor Housing Cover: paso 1, imagen 2 de 2
    • Using a spudger, gently pry off the aluminum drip ring.
  2. KitchenAid Classic Mixer K45SSWH Gasket Replacement: paso 2, imagen 1 de 1
    • Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
  3. KitchenAid Classic Mixer K45SSWH Gasket Replacement: paso 3, imagen 1 de 2 KitchenAid Classic Mixer K45SSWH Gasket Replacement: paso 3, imagen 2 de 2
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
  4. KitchenAid Classic Mixer K45SSWH Gasket Replacement: paso 4, imagen 1 de 1
    • Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  5. KitchenAid Classic Mixer K45SSWH Gasket Replacement: paso 5, imagen 1 de 1
    • Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  6. KitchenAid Classic Mixer K45SSWH Gasket Replacement: paso 6, imagen 1 de 2 KitchenAid Classic Mixer K45SSWH Gasket Replacement: paso 6, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
  7. KitchenAid Classic Mixer K45SSWH Gasket Replacement: paso 7, imagen 1 de 2 KitchenAid Classic Mixer K45SSWH Gasket Replacement: paso 7, imagen 2 de 2
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
  8. KitchenAid Classic Mixer K45SSWH Gasket Replacement: paso 8, imagen 1 de 1
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside-down to prevent grease from leaking out.
  9. KitchenAid Classic Mixer K45SSWH Gasket Replacement, Gasket: paso 9, imagen 1 de 2 KitchenAid Classic Mixer K45SSWH Gasket Replacement, Gasket: paso 9, imagen 2 de 2
    • Use a butter knife or putty knife to remove grease from around the gasket.
    • Place grease in motor housing cover.
  10. KitchenAid Classic Mixer K45SSWH Gasket Replacement: paso 10, imagen 1 de 1
    • Lift the gasket up with your hands or a spuger and remove it.
Conclusión
7 personas más completaron esta guía.
Joey Gavin
Miembro Desde 10/13/14
244 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-28, Maness Fall 2014 Miembro de Cal Poly, Team 14-28, Maness Fall 2014
CPSU-MANESS-F14S14G28
4 Miembros
22 Guías creadas
2 comentarios
I got all the way to the last step of replacing the pin when i notice the mixer seemed to lock there in place and not move. What did i do wrong?
Dawn dawn6463@yahoo.com
Dawn Bennett - Contestar
Hi there - There is a gasket around the engine part that you can see in step 7. Mine tore when I removed it. Is that a bad thing? I put the machine back together and it seems to work.
RES - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 25
Ultimos 30 días: 86
Todo El Tiempo: 9,326
