Saltar al contenido principal
Introducción
Replacing the carbon brushes might sound intimidating, but you don't even have to take the mixer apart to get to them.
Partes
  1. Unscrew the brush cap on each side of the mixer using a flat head screwdriver.
    • Unscrew the brush cap on each side of the mixer using a flat head screwdriver.
    • The brush caps are on springs and will want to fly out, so unscrew them carefully.
  2. Pull out the motor brush from the brush holder on each side of the mixer. One corner of the motor brush is flattened at a 45 degree angle. Check the orientation of the motor brush by looking inside of the hole through a flashlight.
    • Pull out the motor brush from the brush holder on each side of the mixer.
    • One corner of the motor brush is flattened at a 45 degree angle. Check the orientation of the motor brush by looking inside of the hole through a flashlight.
    • In this case, we inserted the new brush with that flattened corner facing the upper left corner of the brush holder.
Conclusión
9 personas más completaron esta guía.
Equipo
Cal Poly, Team 14-28, Maness Fall 2014 Miembro de Cal Poly, Team 14-28, Maness Fall 2014
CPSU-MANESS-F14S14G28
4 Miembros
14 Guías creadas
i looked at the brushes , they are fairly new hardly any wear ,put them back in no power , still wont start ,is there something i could have unhooked while putting in the worm gear , followed all instructions , gears turn perfect , still no power ,
Dennis Jessome - Contestar
Hi Dennis, it is mentioned above " Be sure to insert the new brush with that flattened corner facing the upper left corner of the brush holder." However, on my mixer only one brush must be aligned upper left; the other brush must actually be aligned down right. Look into the slots with a flashlight, you will see which corner has a small metallic piece, or "stop". That's the corner you must align your brush on. Hope this helps..
patfat -
Hello patfat, you are exactly right on those brushes. I been working on this used mixer I got off Ebay for 56 dollars. It ran but I tooK it all apart and cleaned and painted and got some new parts and it would not start. The brush thing is right, one brush upper left and the other one bottom right. I got her fired up and it looks like banana nut muffin time again. Heres one for you.....! You the boss.....
YoDiggity - Contestar
OMG OMG OMG! You are an angel! I scored this brand new looking Kitchenaid mixer at a Goodwill for $3 dollars. Said whaaat? I grabbed it but when I tried it, it would not turn on. I didn't care, I figured I would fix it myself. I followed your instructions and VOILA! It works like a BRAND NEW Baby! LOVE IT! Thank you so much for such easy instructions!
Elizabeth - Contestar
This information was crucial to fixing my mixer. My husband replaced a broken worm gear and my mixer STILL wouldn't start. With the aid of my cell phone camera, which allowed us to increase the size of the photo, we were able to determine which side was upper left and which side was lower right. And when my mixer came on, I yelled and jumped up and down. Thank you!
ellenjoyeh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 52
Ultimos 30 días: 199
Todo El Tiempo: 40,240
