Saltar al contenido principal
Kirby G5 Vacuum Belt Replacement
Qué necesitas
  1. Kirby G5 Vacuum Belt Replacement, Vacuum Belt: paso 1, imagen 1 de 1
    • Place the vacuum at an angle most comfortable and easy to access with the bottom facing upwards.
  2. Kirby G5 Vacuum Belt Replacement: paso 2, imagen 1 de 2 Kirby G5 Vacuum Belt Replacement: paso 2, imagen 2 de 2
    • Remove the three screws holding the base plate to the body of the vacuum using a flat head screwdriver.
    • Place the plate to the side.
  3. Kirby G5 Vacuum Belt Replacement: paso 3, imagen 1 de 1
    • Simply slide the roller out of the vacuum.
    • The belt is attached to the roller on either side.
  4. Kirby G5 Vacuum Belt Replacement: paso 4, imagen 1 de 2 Kirby G5 Vacuum Belt Replacement: paso 4, imagen 2 de 2
    • Slide the vacuum belt out from beneath the wheel holding it in place.
  5. Kirby G5 Vacuum Belt Replacement: paso 5, imagen 1 de 1
    • Insert your new belt and pop the roller back into place.
  6. Kirby G5 Vacuum Belt Replacement: paso 6, imagen 1 de 2 Kirby G5 Vacuum Belt Replacement: paso 6, imagen 2 de 2
    • Secure the plate once again until it clicks into the made grooves.
    • Secure the three screws until tightened.
Conclusión
Make sure to test the vacuum and securely tighten all screws. With that, you’re good to go!
Una persona más ha completado esta guía.
Gina Trojano
Miembro Desde 04/22/21
157 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 61
Todo El Tiempo: 1,088
