Saltar al contenido principal
Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement
Qué necesitas
  1. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement, Disassembling Kinivo ZX100 Mini Portable Speaker: paso 1, imagen 1 de 1
    • Open the circular portion at the top of the speaker by twisting it until it reaches the maximum possible height.
    • Make sure it is twisted fully, as this will allow access to four screws to be removed in the next step.
  2. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: paso 2, imagen 1 de 2 Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: paso 2, imagen 2 de 2
    • Remove the four 12 mm Phillips screws from the enclosure.
  3. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: paso 3, imagen 1 de 2 Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: paso 3, imagen 2 de 2
    • Separate the resonator portion from the base of device to reveal the middle separator of the enclosure. The enclosure will now be in two pieces.
    • Hold the resonator portion of the enclosure gently aside to make sure there is no tension on the black and red wires coming from the bottom portion of the device.
    • Excessive force may disconnect the black and red speaker wires from the circuitry in the bottom portion of the device.
  4. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: paso 4, imagen 1 de 1
    • Separate the very bottom portion of the enclosure (marked in red) by pulling vertically on the red portion of the enclosure (marked in orange).
    • Gently set the very bottom portion and the resonator section aside once they have both been separated.
    • Remove the circuit board with your hands by lifting and sliding the board away from the LED indicator.
  5. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement, LED Indicator: paso 5, imagen 1 de 1
    • LED Locating
    • Locate the three, metal prongs found near the edge of the circuit board. They are found directly behind the LED light.
    • Soldering
    • If you are not familiar with the process of soldering, please refer to an online manual.
    • Heat the soldering iron to operating temperature.
    • Avoid touching the heated tip of the iron to ensure that you do not burn yourself.
  6. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: paso 7, imagen 1 de 2 Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: paso 7, imagen 2 de 2
    • Prong Removal
    • The picture in this step calls for speaker wire, but it can also be applied for the removal of each prong.
    • Remove a single prong by pulling it directly up from the circuit board using tweezers.
    • Repeat the previous until all three prongs have been removed.
  7. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: paso 8, imagen 1 de 1
    • Replacement
    • Obtain a new LED component from a manufacturer.
    • Perform the steps in reverse order to reconnect the new LED to the circuit board.
Conclusión
2 personas más completaron esta guía.
Matthew Kotce
Miembro Desde 03/29/15
266 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 306
