Saltar al contenido principal
Kingston HyperX CloudX Speaker Sponge Replacement
Qué necesitas
  1. Kingston HyperX CloudX Speaker Sponge Replacement, Speaker Sponge: paso 1, imagen 1 de 1
    • Remove the ear cushion from the earphone.
  2. Kingston HyperX CloudX Speaker Sponge Replacement: paso 2, imagen 1 de 2 Kingston HyperX CloudX Speaker Sponge Replacement: paso 2, imagen 2 de 2
    • Remove four 11.2 mm screws from the earpiece using a Phillips #00 screwdriver.
  3. Kingston HyperX CloudX Speaker Sponge Replacement: paso 3, imagen 1 de 2 Kingston HyperX CloudX Speaker Sponge Replacement: paso 3, imagen 2 de 2
    • Use a spudger to pry the top plate away from the motherboard.
    • There will be a groove in between the two plates to insert the spudger.
  4. Kingston HyperX CloudX Speaker Sponge Replacement: paso 4, imagen 1 de 1
    • Use the metal spudger tool to scrape off the old foam pad and any remaining glue.
    • The plate does not have to be completely clean after removal, just clean enough to securely attach the new sponge.
  5. Kingston HyperX CloudX Speaker Sponge Replacement: paso 5, imagen 1 de 1
    • Line the edge of the headphone plate where the original pad was with superglue.
    • Press the new sponge into the glue and allow it to dry fully.
    • The new sponge may need to be cut to size in order to fit on the headphone plate.
    • Make sure the glue is completely dry before reassembling your device. Failure to do this may result in damage of your device.
Conclusión
Kosie
Miembro Desde 03/01/23
121 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 85
