Saltar al contenido principal
Kingston HyperX Cloud II Speaker Wire Repair
Qué necesitas
  1. Kingston HyperX Cloud II Speaker Wire Repair, Kingston HyperX Cloud II Speaker Wire Repair: paso 1, imagen 1 de 1
    • Pulling along the edges, take off the ear padding.
  2. Kingston HyperX Cloud II Speaker Wire Repair: paso 2, imagen 1 de 2 Kingston HyperX Cloud II Speaker Wire Repair: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 11 mm screws from the bracket support.
  3. Kingston HyperX Cloud II Speaker Wire Repair: paso 3, imagen 1 de 3 Kingston HyperX Cloud II Speaker Wire Repair: paso 3, imagen 2 de 3 Kingston HyperX Cloud II Speaker Wire Repair: paso 3, imagen 3 de 3
    • Remove the inside bracket support, and then remove the outside bracket support.
    • Expand and remove the microphone speaker from the frame.
  4. Kingston HyperX Cloud II Speaker Wire Repair: paso 4, imagen 1 de 3 Kingston HyperX Cloud II Speaker Wire Repair: paso 4, imagen 2 de 3 Kingston HyperX Cloud II Speaker Wire Repair: paso 4, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the two 7.90 mm screws from the red support attached to the microphone speaker.
  5. Kingston HyperX Cloud II Speaker Wire Repair: paso 5, imagen 1 de 3 Kingston HyperX Cloud II Speaker Wire Repair: paso 5, imagen 2 de 3 Kingston HyperX Cloud II Speaker Wire Repair: paso 5, imagen 3 de 3
    • Separate the red frame support from the microphone speaker by putting it to the side.
  6. Kingston HyperX Cloud II Speaker Wire Repair: paso 6, imagen 1 de 2 Kingston HyperX Cloud II Speaker Wire Repair: paso 6, imagen 2 de 2
    • Remove the four 11 mm screws on the speaker frame with a Phillips #2 screwdriver.
  7. Kingston HyperX Cloud II Speaker Wire Repair: paso 7, imagen 1 de 3 Kingston HyperX Cloud II Speaker Wire Repair: paso 7, imagen 2 de 3 Kingston HyperX Cloud II Speaker Wire Repair: paso 7, imagen 3 de 3
    • Remove the headphone speaker frame.
    • Solder the detached blue wire onto the driver.
    • Be cautious not to solder the wrong wire.
  8. Kingston HyperX Cloud II Speaker Wire Repair: paso 8, imagen 1 de 1
    • Solder the green wire onto the driver.
Conclusión
Equipo
IUPUI, Team 1-4, Harley Spring 2023 Miembro de IUPUI, Team 1-4, Harley Spring 2023
IUPUI-HARLEY-S23S1G4
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 24
Ultimos 30 días: 118
Todo El Tiempo: 1,865
