Saltar al contenido principal
Kingston HyperX Cloud II Speaker Drivers Replacement
Qué necesitas
  1. Kingston HyperX Cloud II Speaker Drivers Replacement, Speaker Drivers: paso 1, imagen 1 de 1
    • Plug in and warm up your soldering tool prior to use. Most manufactures will specify on the packaging or tool itself.
    • Twist and place the headphones on your workspace as shown.
  2. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 2, imagen 1 de 1
    • Remove the ear cushion by pulling it away from the plastic lip the cushion is secured around.
  3. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 3, imagen 1 de 1
    • Remove the four screws securing the first panel by turning them to the left with a Phillips #2 screwdriver.
  4. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 4, imagen 1 de 3 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 4, imagen 2 de 3 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 4, imagen 3 de 3
    • Warning: Your soldering tool at this point should be extremely hot. Coming into contact with it will result in serious burns. Only grip from the handle.
    • Place the panel still attached by the wiring onto your work surface if possible, or onto the headphone frame as shown in the images.
    • Use your soldering tool to quickly melt the solder and remove each wire from the speaker's motherboard.
  5. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 5, imagen 1 de 1
    • Using your hands, carefully pry apart the two plastic panels from the edges. They are not secured by any means and should easily come apart.
  6. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 6, imagen 1 de 2 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 6, imagen 2 de 2
    • Using a small heat gun or household blow-dryer, apply heat near the perimeter of the speaker itself.
    • The perimeter of the speaker is easily visible with the black circle surrounding the metal face covering.
  7. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 7, imagen 1 de 3 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 7, imagen 2 de 3 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 7, imagen 3 de 3
    • Using a small cloth or towel, press onto the metal face plate with your thumbs while using your other fingers to hold back the outer plastic frame. It will require considerable force to remove.
    • It may help to have the blow-dryer positioned to give constant heat, or have someone hold it for you.
  8. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 8, imagen 1 de 2 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 8, imagen 2 de 2
    • This step simply outlines all three pieces separated, and another image placing the new speaker next to the plastic frame it will be going into.
  9. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 9, imagen 1 de 1
    • Apply epoxy to the inner ring of this plastic frame.
  10. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 10, imagen 1 de 3 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 10, imagen 2 de 3 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 10, imagen 3 de 3
    • Press the new speaker into place with one thumb or both, ensuring a flush fit.
  11. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 11, imagen 1 de 2 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 11, imagen 2 de 2
    • Place the newly assembled panel onto the headphones and part of the cushion as shown in the image. This way is easiest to keep the speaker within comfortable distance of the wiring from the headphones.
    • If the original solder from any of the wires was lost, you will require a small extra roll.
    • Solder each wire to the new speaker's motherboard, beginning with the blue one onto the largest of the three metal plates. In this case, start on the right. The red wire will be in the middle. The blue wire will connect on the left side.
  12. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 12, imagen 1 de 2 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 12, imagen 2 de 2
    • Observe the small protruding rectangular notch on the top of the plastic frame, and on the actual ear-cup of the headphones.
    • With each wire secured to the new speaker, we are ready to insert it back into the headphones.
    • Flip the panel over and insert the notch first. Let the plastic frame fall back into the earcup of the headphones.
  13. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 13, imagen 1 de 3 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 13, imagen 2 de 3 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 13, imagen 3 de 3
    • Pay attention once again to the notch on the remaining plastic panel, and the notch still visible on the earcup of the headphones.
    • Flip the plastic panel and again align the notch with the one in the earcup. It should fall into place with little to no force required.
  14. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 14, imagen 1 de 1
    • Re-secure the panel with the four screws from earlier by inserting them in each corner and turning to the right with your Phillips #2 screwdriver.
  15. Kingston HyperX Cloud II Speaker Drivers Replacement: paso 15, imagen 1 de 2 Kingston HyperX Cloud II Speaker Drivers Replacement: paso 15, imagen 2 de 2
    • Re-attach the leather earcup by pulling and stretching the flaps provided around the plastic lip on the actual headphones.
Conclusión
Congratulations if you followed along and fixed your headphones. I hope it will help many people restore their headphones to working order.
Matthew
Miembro Desde 01/24/24
241 Reputación
1 Guía escrita
Equipo
2 comentarios
How about the quality of sound ? In indonesia i just found speaker hifi 50mm with 32ohm, is that okay if i use that ?
Pablo Es Teler - Contestar
Quality of sound is excellent, no difference between the factory speakers. Yes those are fine, as long as they are 50mm. :)
Matthew -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 27
Ultimos 30 días: 115
Todo El Tiempo: 245
