Saltar al contenido principal
Introducción
Removing the Kindle Voyage back panel is a necessity for replacing all the other parts of the device.
Partes
No se especificaron partes.
  1. Insert a plastic opening tool between the plastic panel shown on the device. Use the tool to pry the plastic away from the device.
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture.  For reassembly, note that the top two and bottom two screws are different sizes.
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Once the screws are removed, the back panel can slide off the device. Once the screws are removed, the back panel can slide off the device. Once the screws are removed, the back panel can slide off the device.
    • Once the screws are removed, the back panel can slide off the device.
  4. Remove the magnetic component with the magnetic head of the aluminum driver. Remove the magnetic component with the magnetic head of the aluminum driver.
    • Remove the magnetic component with the magnetic head of the aluminum driver.
Conclusión
Una persona más ha completado esta guía.
Sean Yap
Miembro Desde 22/01/15
1,169 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 19-12, Maness Winter 2015 Miembro de Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Miembros
6 Guías creadas
4 comentarios
I'm having trouble getting the last two clips to snap back together on the top of the device. I'm pinching them together at the top, but nothing happens. It doesn't seem like it should be this difficult. What do you advise? Thanks!
Hannah BP - Contestar
I have the same problem. It would be very helpful to get a tip here.
Sylvia Liemer - Contestar
I 'm having the same problem with Hanna:
I' having trouble getting the last two clips to snap back together on the top of the device. I'm pinching them together at the top, but nothing happens. It doesn't seem like it should be this difficult. What do you advise? Thanks!
panthalas15 - Contestar
Years later, but I just replaced the battery in mine and figured this out. You have to align the top clips first (and may have to lightly pry them open before you do that). Then bow the piece of plastic slightly and get the bottom clips in.
Patrick Cohen (ig88b) -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 2,066
