Introducción
Use this guide to properly replace your speakers.
Qué necesitas
Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
Use the pointy end of your Spudger to separate the Speaker's connector from the motherboard on both sides.
Casi Terminas!
Conclusión
