Saltar al contenido principal
Kindle Touch 3G Card Housing Replacement
Qué necesitas
Resumen del Video
  1. Kindle Touch 3G Card Housing Replacement, Back Cover: paso 1, imagen 1 de 3 Kindle Touch 3G Card Housing Replacement, Back Cover: paso 1, imagen 2 de 3 Kindle Touch 3G Card Housing Replacement, Back Cover: paso 1, imagen 3 de 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
  2. Kindle Touch 3G Card Housing Replacement: paso 2, imagen 1 de 2 Kindle Touch 3G Card Housing Replacement: paso 2, imagen 2 de 2
    • Gently lift the bottom and slide the panel off.
  3. Kindle Touch 3G Card Housing Replacement, Battery: paso 3, imagen 1 de 3 Kindle Touch 3G Card Housing Replacement, Battery: paso 3, imagen 2 de 3 Kindle Touch 3G Card Housing Replacement, Battery: paso 3, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch 3G Card Housing Replacement: paso 4, imagen 1 de 3 Kindle Touch 3G Card Housing Replacement: paso 4, imagen 2 de 3 Kindle Touch 3G Card Housing Replacement: paso 4, imagen 3 de 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: paso 5, imagen 1 de 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: paso 5, imagen 2 de 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: paso 5, imagen 3 de 3
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
    • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
Conclusión
3 personas más completaron esta guía.
Adam Yerly
Miembro Desde 01/20/15
1,933 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 19-5, Blackwell Winter 2015 Miembro de USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Miembros
8 Guías creadas
2 comentarios
Hey, thanks for your guide!
I, however, have one question, maybe I misunderstood - is it possible to add a 3G module to a kindle touch that didn't have one installed by default?
Would it work?
Curious_Guy_Threepwood - Contestar
You would need to add more than just a 3G module - there’s a slot for a SIM-card tray and special Amazon SIM that are missing from non-3G Kindle Touches. I don’t know if there would be any software changes that would need making.
Darren John de Lima -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 2,019
