Saltar al contenido principal
Kindle Paperwhite 2nd Generation Screen Replacement
Qué necesitas
  1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
  2. Kindle Paperwhite 2nd Generation Screen Replacement: paso 2, imagen 1 de 2 Kindle Paperwhite 2nd Generation Screen Replacement: paso 2, imagen 2 de 2
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Screen Replacement: paso 3, imagen 1 de 1
    • Carefully lift and remove the mid-frame.
  4. Kindle Paperwhite 2nd Generation Screen Replacement: paso 4, imagen 1 de 1
    • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
Conclusión
5 personas más completaron esta guía.
Tyler Davis
Miembro Desde 09/15/16
1,574 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 11-2, Blackwell Fall 2016 Miembro de USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Miembros
7 Guías creadas
2 comentarios
My opening tool is orange. Will this still work for me?
FoxRunTime - Contestar
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 65
Todo El Tiempo: 11,927
