Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Disassembling a tablet often requires some gentle prying of the frame. Be sure to exercise care during these first few steps(disassembling), and do not lose your screws! The Paperwhite is a sturdy tablet that can be broken down into just a few components. This guide will show you how to replace a faulty screen.
  1. Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
  2. Remove the eleven 3.2 mm Phillips 000  screws from corners of mid-frame and from behind the black strip as shown. Do not forget the screw in the middle of the black adhesive strip.
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Carefully lift and remove the mid-frame.
    • Carefully lift and remove the mid-frame.
  4. The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
    • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
Conclusión
4 personas más completaron esta guía.
Tyler Davis
Miembro Desde 15/09/16
1,314 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 11-2, Blackwell Fall 2016 Miembro de USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Miembros
5 Guías creadas
My opening tool is orange. Will this still work for me?
WhiteTail - Contestar
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 78
Todo El Tiempo: 9,168
