Saltar al contenido principal
Kindle Paperwhite 1st Generation Case Replacement
Qué necesitas
  1. Kindle Paperwhite 1st Generation Case Replacement, Case: paso 1, imagen 1 de 2 Kindle Paperwhite 1st Generation Case Replacement, Case: paso 1, imagen 2 de 2
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
  2. Kindle Paperwhite 1st Generation Case Replacement: paso 2, imagen 1 de 3 Kindle Paperwhite 1st Generation Case Replacement: paso 2, imagen 2 de 3 Kindle Paperwhite 1st Generation Case Replacement: paso 2, imagen 3 de 3
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
  3. Kindle Paperwhite 1st Generation Case Replacement: paso 3, imagen 1 de 1
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 3-33, Amido Winter 2013 Miembro de Cal Poly, Team 3-33, Amido Winter 2013
CPSU-AMIDO-W13S3G33
4 Miembros
17 Guías creadas
2 comentarios
Thanks for the guide but do you know anywhere can we get a replacement case?
jerryw - Contestar
4 years too late but I found this
Pao-Tang Kao - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 26
Ultimos 30 días: 101
Todo El Tiempo: 9,417
